no connection
I will let it sit for half hour , it is doing the standard beep beep now.
wait Before that I took out sd card and checked it said succes 01.09.0060
underneath it says firmware on card is identical or older than the current firmware
We sure don't want 1.96 crap!
sorry , went all the way to the botton of the ab file and it said :01.06.0040 . abort
current firmware doesn't support downgrade
use a different version of firmware to downgrade current version
Ok so I believe we will need to go with 1.7 which in this case should work. The only current problem I have is I don't have a copy of that version, do you?
Hi good morning to you , no I don't . is there anywhere I could download this ??
I searched online last night until I fell asleep with no luck. Need to post a thread and someone will have a link. Btw, you have the pro or adv?
Did you see the info about the new Mavic yet?
It's the new dji drone they will be announcing it in 45min.
The remote controller setup is pretty crazy. Not what we're use to seeing anyhow.
Any Luck with that version?
src72
