Newbie Questions
Got my P3A yesterday, can I use my 10 inch tablet at the controller screen ?
Also do I need to lock the gimbal when I put the Phantom 3 in the hard shell bag and travel to fly the phantom.
You can if the tablet is not wider than 6.75". Otherwise, you'll need an extender (like this one).
It's 237 X 170 X 7.5 mm, does it mean I need extender
170 mm is 6.69 inches. It'll fit as long as you don't have it in a case.
I will give it a shot, I don't use a case so that's good.
Also what about the gimbal protection ?
I havent tested but woupdnt be suprised to learn that dropping your phantom inside a hardcase or without the protector could result in a danaged gimble.... it seems very fragile and flopping around while powered off can only increase the chance of damagimg something.
Rather than start new thread, thought I should post my question here
Sorry; but your tablet is way to big for the hood you have bought.
- DJINSP-57 Hood Maximum device size : 205mm x 145mm x 128mm
- Cube 9X Dimensions : 372 x 212 x 40
Ok then, what to get.
