Trust me when I tell you that you're about to make a serious mistake. If you look at the comparison picture of the two props, the DJI prop hub is a molded piece that spins on....the CF prop has a silver ring at the hub and is in fact a separate piece. I bought the exact same props and luckily it decided to come apart as I was taking off and my Phantom just flipped over with no damage. When I started to examine the props to see what happened I could actually unscrew the top hub and bottom silver ring and was left with an old style prop that needs nuts. What they did was design a hub and screw on ring that converts the old props to self-tightening ones. Look at yours closely and you'll see what I'm talking about and DONT FLY with them if you value your equipment.
*** I forgot to add that the hub and the silver ring tighten the same way that you spin the prop on so they in effect are self-tightening pieces
