New phantom 3 professional owner
Hello all, I have recently bought a phantom 3 professional and am having problems with the update. I have searched over the forum looks for a solution. Basically the update to the drone was successful in the text file. After the update I switched it back on to hear it beeping away its beeps twice continually. Most of the post I have seen are about single beeping.
I would appreciate any advice to resolve this issue.
This is the video that I used when I first got my P3P, to upgrade my firmware, it is no good now for the controller update, because DJI GO app updates the controller for you.
Hope this helps, if not some of the other guys on here will help you I am sure. Happy flying.
Did you remove the bin file from the SD card after the update? If not, you will get some beeping as it starts the update process again to discover that it's already been done and then stops. All of this should only take a couple of seconds though. In any case, once you have updated the drone and _all_ of the batteries, remove the bin file.
Thank you both. tcope I had not removed the bin file thanks again.
intertronixlabel
