NEW Phantom 2 battery with 5400mah
FASTFJR said:
Ditto........2 minutes longer and 20 bucks cheaper.
Probably much shorter lifespan and I imagine it doesn't calculate remaining charge nearly as well as OEM.
Fink
I really thought I posted on this,
but I wouldn't trust it,
if it was for a car or other loess expensive item that if the batter failed it wouldn't drop out of the sky and damage
my investment.
EDIT: I did on a cross post viewtopic.php?f=27&t=11966
mah measurements are by no means reliable and is hugely subject to gaming. What is the cut off voltage? I am pretty sure you can get dji's 5200 to discharge 5400mah if you drain it to 0v...
What is promising is that someone is able to circumvent the battery lock though. I would get one for testing if it was like $80-100, but not at only $20 less.
axipap
