New P4P Battery Fitting
Minneapolis, MN
I just received my new P4P from Amazon. Below are the pictures of how far my battery will go in. It does seem secure on the both latches(top & bottom). I checked connectors on both the battery and the unit itself and they seem fine. But I can't stop thinking this doesn't look or feel right. I have not flown it yet.
Do any of your P4P battery sit like this while fully inserted?
Should I return it?
I had a battery compartment that allowed major free play of the batteries. I returned it for a replacement, which holds almost too tight but workable. I've seen other threads that indicate this is a fairly common problem, either too tight or too loose. I would say return it and try again. You don't want a battery disconnecting even for a split in flight.
I notice this is posted on the P4 Help and the aircraft is a P4P
DonT
