New camera, bad video quality
That should work. Next stupid question (it's caught people before). You did remove the plastic protective skin from the lens .....
I wish it was the plastic skin. Actually I used a filter.
And make sure your sharpness / contrast / saturation are set to zero.
That's "standard", right? O O O.
Just now put it on "auto" (don't know why I didn't try that before) and did a short vid and the results were a lot better. So It's nice to know it's not the camera. I might be doomed to only fly auto if I can't get this thing dialed in.
AFAIK, all 'auto' does is fix the shutter speed and ISO, none of which appeared to be a major issue. Auto actually allows the sharpness / contrast / saturations to values to be used. Although again, you don't appear to be using the DJI Go app so it is possible that whatever you are doing is mucking about with the settings some where.
FWIW, I often shoot auto as lighting can change drastically.
The first thing I would do if I saw video like that is... Use the video on the sd card. That looks like he live feed.. And a bad live feed at that. If it is the video from the card I would check the camera settings to make certain I am recording 4K not 720p.
Yes, it's DJI Go app. And no matter what my settings, the videos looked muddy and flickering. Auto seems to work better.
Here it is on auto:
Somehow, you are still not uploading the full 4k file. Are you pulling the file from the SD card and not the phone/tablet/computer memory?
Here are two screenshots. The first is yours, see the black border? That is like 640x480 resolution. Have you somehow changed the quality on youtube to something lower? Or maybe your IP wont allow for large file uploads?
The second screenshot is of a 4K upload.
If I may add. You have set D-Log on, so did you color grade it?
see
for more info and whys.
He said he pulled the file from the SD card.... I assumed that the bars were due to YouTube but I know little of uploading to YT since I use Vimeo.
But yeah, all the data suggests a low rez file with nasty compression.
The 2.7k video coming out of my phantom 3 advanced ( my pro works fine ) looks like pixelated and blocky, anyone have a fix
Change the video settings in the GO app. Or you might just be flying when there is not enough light.
wkflysaphan4
