Need some advice-P2v
Hello all
I've got a P2v with pice O ship,Egg cam,no video.Every thing else works.its a card,in the cam
that scrambled? From an update,I'm able to bind the controller no prob!The cam still records fine.Gimble works.
I would like to no if any one has bin able to add a separate Wifi card in the body of the P2
To make that egg cam broadcast? An what is the mini plug pin out that plugs
In to the body of theP2. Or? Is that used to send an receive an power the cam,hope someone
Can help me,thanks all.
It’s most likely a board in the FC200 that’s bad. Have had seversl with that issue as well as many other members. Was the last update that messed up most if I remember correctly and is slot on it if you go way back in this section.
It is possible that’s not it but bet it is.
Disconnect the cables between the egg and bottom of the drone
maybe spray a little electronic cleaner or detoxit in the connector
and try that. you never know.
Reactions: Artic view
Thanks for the reply,still working on it.
Reactions: dirkclod
Good luck. I have replaced the wifi board inside the drone before
but that black goo of death is a pain to get off the connecters
or was for me.
Maybe try this. Hadn’t seen this till now looking for you.
Reactions: crash1sttime
Its my video mate.
Big thank you.
let me know if it works for you, ive repaired about 10 so far using this method
Reactions: dirkclod
Its my video mate.
Well you should have posted it ?
I never saw the post mate and I’m sure it’s in the FC200 thread
Man it’s all over most likely I just hadn’t seen it. After I went into
my first fc200 I just sent mine to Jdot to fix for me way back.
He liked messing with em and that worked out good ?
Its my video mate.
I've got the just of it,,an should be able to work it all out.only thing I don't have is the USB board, could I salvage one from an old computer or something like that,? Thanks again
no they are specific and need to be purchased
