Need info about gimbal.
If you upgrade to the new board it will lighten your load quite a bit.
E
Right, if you gimbal is operating now with all the extras that are in the Phantom case, you are good to go.
E
If you are buying the Zenmuse gimbal, then buy the upgrade main board as well. You will not have to purchase the
PMU V-2 module, or use the GCU V-1 module, that comes with the gimbal.
It will save you a lot of headache, trying to stuff all the modules, and wires inside the shell. The cost is almost the same
as the PMU V-2 , plus you get the lever kit for the DJI tx.
+1 for sure.
E
