My Range has been reduced greatly.
I truly believe that is wifi from other equipment in the area that interferes with the phantom 3 standard.
Not, I flew in the same place I do most of my flying, in a rural area with no buildings or wi-fi around. Flew fine for months, then suddenly the next day it would only go to about 75m and then RTH.
@Sprocky
Yep, my results were at my house. When it worked like it should, it was better than the P2V+.
When I started checking / testing the problem.
Remote control signals (weak, poor, disconnected) would happen within less than 100'.
I didn't even have to start the motors.
I could throw a tennis ball easily farther than the distance between the remote and the Phantom.
Rod
I replaced all 3 wifi cables in the remote and made sure the 5.8 plug was shielded. Took it for a test today and no improvement. I got about 900ft and it RTH. So I can only assume something on the main circuit board is toast? Either way, anyone looking for a 2 month old P3S that flies very limited range even with alfa panels, let me know lol.
Once you have that dbs on buddy you'll be busting out some distance :)
After scrolling this thread sounds like software to me.
@yamisolja04
Why did you start a new post?
HOW CAN I DOWNGRADE MY FIRMWARE PLEEEASSEE HELP
I was waiting for you and maybe some others to answer the question on post #13
I thought you would comment on this on, if you just did a firmware or not. :rolleyes:
It wasn't clear what your said in your first post "I have the lastest updates installed"
I even did a bump. :eek:
Rod
Hello
sorry for the confusion I still am having range problems. I am now attempting to downgrade my firmware. I currently have 8.1.10 installed. I have downloaded the Bin file for firmware version 1.7.9. I formatted my SD card and place the Bin file on the SD card by itself. The firmware installs on the aircraft no problem but when I restarted The aircraft I have a main controller error..the aircraft will not successfully calibrate that Imu either.. I can successfully re-install the 8.1.10 and the main controller error message goes away .... I really need help downgrading to a version that works...if anybody can help me I would greatly appreciate it if you have Facebook video or Skype I am willing to pay via PayPal for help
Falcoray
