- Joined
- Aug 21, 2015
- Messages
- 787
- Reaction score
- 148
- Age
- 56
I'm anxious to try it out on my power inverter when I travel.
Ive used an inverter with a single battery with no issues. Don't have, never attempted a hub with 3 batteries.
Assuming your inverter is of sufficient rating to handle the current, I expect it will work great for you. Nothing better than to be able to charge while out flying instead of having to head home when you're out of batteries. HahaI'm anxious to try it out on my power inverter when I travel.
The solution is just to by two of the separate single chargers that come with your Phantom. Works great and all my batteries charge at once. Not as elegant as some solutions.
This one works quite well, will charge 3 batteries and the transmitter also -- all at the same time. The batteries will charge full in about an hour.Thought of that, however ends up being expensive. The blue charger is a nice piece of kit. [emoji1]
Mark.
Charger for DJI Phantom 3 charging 3 batteries and remote control at the same time
Any charger simply puts out 11.7 volt and a number of amps. It's not magic. It's just a power outlet.I rather to buy the original one from DJI. It's more trusted than any other thrid party charger. I use charging hub from DJI for phantom 3. It work really well. U can buy phantom 3 and spare batt. Why u people risking your phantom by using third party charger? It only $40-$50 different.
Yup any Power suply that can voltage for 4S. But the probs is that other third party charger can suply stable voltage and current for sure?Any charger simply puts out 11.7 volt and a number of amps. It's not magic. It's just a power outlet.
