Movie only on iPad editor. None on SD
Hi!
Today I went shooting some amazing shots and when I got home, plugged in the sd-card in the USB and there was no new fotage. I had my sd card in as usually and I saw the time going while recording.
I watched my iPad in DJI Go editor and there I can see the material in low and laggy format.
Is there a way to recover it? What went wrong?
Thanks!
I'm guessing it's a bad card. There is software to recover files that can't be viewed. You'll have to Google it.
Good luck.
Tony
But I did put in the card right after to test and it did record and I could view the footage right away in the computer.
So wierd.
Good luck.
Tony
Try to connect the gimbal to your computer with a cable and see if you can see it there
Hi!
Thanks!
Did you by chance power off you bird while still videoing ?
Reactions: J Dot
robvalduga
