When doing something like that, does it matter where you connect the directional antenna? Do all three connections act the same?I am putting 2 x 9dbi omni antennas and one 18 DBI netgear patch antenna ( ant24d18) on the decooler ....when it arrives. The netgear patch has an azimuth of 60 degrees and an elevation of 30 degrees for beam angles. This I believe will be the best of both worlds and should offer way excess of 3 km while maintaining reliable feed at both close and long range.
COtto1984 said:When doing something like that, does it matter where you connect the directional antenna? Do all three connections act the same?I am putting 2 x 9dbi omni antennas and one 18 DBI netgear patch antenna ( ant24d18) on the decooler ....when it arrives. The netgear patch has an azimuth of 60 degrees and an elevation of 30 degrees for beam angles. This I believe will be the best of both worlds and should offer way excess of 3 km while maintaining reliable feed at both close and long range.
Getting awfully close to the floor of the DEN Class B airspace (8000 MSL in that neighborhood) and I regularly fly my full-size airplane through that area close to that altitude coming into Jeffco (trying to stay out of said airspace). You might want to save the high altitude stuff for the boondocks. Neither of us would like it much if I hit your P2V doing 200 knots.davidbarwin said:1,170 feet above I-70 & Sheridan in Denver
themosttoys said:For those that are using the Docooler. Are you having any problems maintaining a connection? For some reason I'm unable to maintain a solid connection at any range. It will connect just fine, but then the wireless signal strength (inthe DJI app) drops until it disconnects (temporarily). It will reconnect right away, but the cycle continues. My phone maintains a solid and consistent connection to the Docooler, it's the P2V itself that does not seem to like staying connected. Using the stock DJI repeater I have no problems maintaining a connection. I followed the RemE instructions (copied below for others convenience):
Overview, what we will do is to first gather the data from your existing Range Extender/Camera network. It will be needed to fill in the boxes in the Router config screens. Armed with that knowledge, we configure the router to mimic your stock extender.
1 - Normally you start with a working Vision WiFi Range Extender setup, power up the extender, the Vision, then your Phone/Pad and go to Settings>WiFi, and connect to the Extender Network.
2 - While still in the phone/pad WiFi settings, touch the (i) info icon to the right of the currently connected Range Extender network. In this information page, jot down the "IP Address", "Router", and the "Search Domains" information.
3 - Now Open the DJI Phone App and go to Settings>General>Binding. In here you will see the "Current Binding" data. Copy down the SSID number, this is the hidden ID of the Vision Camera, note that it's "FC200_the last 6 digits of its MAC address", just good to know. Note - The other instructions I saw had you reset the Extender and then Re-Bind the Camera using the QR Code from the shipping box and the manual (pg16), this should not be necessary if you have a normally working system already as you should be able to just read the current data. I have tried it both ways and it does work to get the Camera's hidden SSID number to show up if that information is blank in this screen for some reason.
Now we will configure the router. But first, I thought I'd mention something about using a second, spare, Range Extender. I was going to get a 2nd extender to modify it with big antennas etc. as others have done. I took the 2nd extender and found that I could bind it to the same Vision using the QR code from the Vision Shipping box (I keep a copy of this QR code in my carry case). The 2nd Extender shows up as a 2nd network on the iPad. So you can carry a spare extender and use one OR the other with no changes needed on the Vision, just connect to the which ever extender you need, each has a unique network name, easy!
Now, back to the Router.
4 - Unpack it and connect its antennas, don't operate it without antennas!
5 - Power it up with its AC adapter, connect a LAN cable to your laptop's LAN port to port 1 of the Router (any port really, except the WAN port).
6 - Open your laptop's browser and type in this URL 192.168.1.254
This should open the router's built-in WLAN Access Point web interface.
7 - We will be only configuring a few items, navigate using the Site Contents bar on the left side of the screen beginning with "Operation Mode". We will NOT use the setup wizard.
8 - Click on "Operation Mode" on the left bar, now select the "Bridge" radio button. Then click on "Apply Change" button at the bottom. It may restart, but don't worry it will come back.
9 - Now click on "Wireless" on the left bar and below that, select "Basic Settings". In here you select "Client" for the mode. for SSID you type in the SSID information from your Vision camera. Check the box near the bottom "Enable Universal Repeater Mode". Lastly in the "SSID of Extended Interface" box type in the name you want this Router Network to show on your Phone/iPad. I chose "Phantom_Ranger" as mine. Now click on apply changes, it may restart, no worries.
10- Now click on "TCP/IP Settings" on the left bar and select "LAN Interface".
IP Address, Enter the info from your phone's "Router" field.
DHCP Client Range, enter the IP address from your Range Extender's WiFi setting as the start range, and a higher address as the end range (doesn't really matter).
Domain Name, enter "lan", then apply changes.
Highcloud said:themosttoys said:For those that are using the Docooler. Are you having any problems maintaining a connection? For some reason I'm unable to maintain a solid connection at any range. It will connect just fine, but then the wireless signal strength (inthe DJI app) drops until it disconnects (temporarily). It will reconnect right away, but the cycle continues. My phone maintains a solid and consistent connection to the Docooler, it's the P2V itself that does not seem to like staying connected. Using the stock DJI repeater I have no problems maintaining a connection.
Could be your phone is getting swamped with signal and overloading the signal register? Try standing further away from the decooler or put a wall between you and it, as it's pushing out 1500mW. See if makes a difference
gpauk said:Highcloud said:Could be your phone is getting swamped with signal and overloading the signal register? Try standing further away from the decooler or put a wall between you and it, as it's pushing out 1500mW. See if makes a difference
Yes -- I find if I get too close I get a bit of a problem - it shows zero bars but still works fine. Never lost connection to the PV though.
gpauk said:I originally used an amp that's a kit from
https://www.minikits.com.au/electronic-kits/rf-amplifiers/rf-high-power/6cm-1W-Amplifier
I'm now testing
http://www.aliexpress.com/item/2013-Newest-5-8GHz-1000mW-802-11A-N-SMA-Broadband-Wi-Fi-Amplifiers-Booster-Wholesale-Retail/1246044213.html
BenDronePilot said:I am going to look into making a switchable antenna mod to the WiFi repeater. I will use an external screw connector and toggle switch that will allow me to use the WiFi repeater as is or with the flick of a switch use an external antenna that can be easily attached or removed.
I also may try the same thing with the transmitter allowing me to toggle between the stock antenna or a higher gain screw in. If anyone has any parts list suggestions let me know. And should I be concerned with a loss of gain from the toggle switch? Will there be added resistance?
And one last mod will be adding an external micro USB to the controller so I don't have to take it apart every time I want to configure or update the firmware,
Super-D said:Have you come to any conclusion which one is better? I would be interested in knowing. The kit seems ok but for anyone wanting sort of a "plug and play" option the second one seems to be better as far as setting up and installing for the average person.
David
themosttoys said:Super-D said:Have you come to any conclusion which one is better? I would be interested in knowing. The kit seems ok but for anyone wanting sort of a "plug and play" option the second one seems to be better as far as setting up and installing for the average person.
David
When I amplify the controller, I will be going with the Sunhans.
Super-D said:Is that because of performance or just ease of use?
How would you implement that thing without having a bunch of wires everywhere? Or would this be a deal where you need to put the antenna and amplifier remotely and run a cable to them from the TX?themosttoys said:Super-D said:Have you come to any conclusion which one is better? I would be interested in knowing. The kit seems ok but for anyone wanting sort of a "plug and play" option the second one seems to be better as far as setting up and installing for the average person.
David
COtto1984 said:How would you implement that thing without having a bunch of wires everywhere? Or would this be a deal where you need to put the antenna and amplifier remotely and run a cable to them from the TX?
storm_333 said:Okies, I'm, new to this, and my P2V hasn't even arrived yet. I've read through all 63 pages of this post and am suffering from information overload :shock: Am I right in saying that people can expect to get a long range (1Km+) from the standard 5.8Ghz remote control transmitter with no modification? In FCC mode of course. And that a 2.4Ghz 9dbi omnidirectional antenna should increase the range of the FPV wifi?
