missing startup sound PV1
when I start up comes the normal sound but not the last dit - dit - dit - dit - Sound
I installed a switch to the 2 batteries when I had to pick the new contact, I came to turn the wires wrong, reversed the + and - incorrectly - seeeh - engines could not run?
I had to replace both green and red esc. Now the motor runs fine, and all things look normal on the PC - what could be wrong
at start it is looking for the satellites and it finds the satellites and reporter green, red, red, red finally green it looks normal
I tried my PV2 and found 7 satellites at the same place.
is there anyone who knows what that sound means - dit dit dit dit
how to insert a picture - from my ipad?
Paw252 - Greenland
It does not appear that there is no answer to my question - I have sent the issue to DJI support - to find answers to why the sound dit, dit, dit, dit not going at startup
when I get the answers I put it in here in the forum
All the best!
paw252 Greenland
PV1 with built-in power switch
Paw252 Greenland
PV1 with integrated power switch and here you can see the rear with 2 batteries
Paw252 Greenland
thanks for your intreresse
last summer I had problems with the toilet bowl effect - so I built a new gps as I change the degrees here is 26 degrees minus the geographic North Pole
Difference of sound on Phandom 1 and the sound of Phantom 2 vision
Phantom 1 has the normal startup sound -
phantom 2 vision has also the normal sound plus 4 bib bib bib bib
in wait with ordering and installation of four new esc. I had forgotten the sound of phantom 1 - since I mostly worked with vision
Now it's just waiting with better weather here in Arctic
paw252 Greenland.
apktuti
