micro chip
LADY LAKE FLORIDA
Want to upgrade micro chip to at least 32gb.assume new chip needs to be formatted.I could not find instruction in manual.Any body know where it is or how i should do it ? Thanks guys av8r
I think you are talking about your memory card? It is called a Micro Secure Digital card. (SD Card) It is in a small slot on the side of your gimble, press in gently with a fingernail and it will release and spring out, then format it with a windows computer with a Memory card reader. Read your book
Is it best to do the format from the P4 thru a USB cable to my ipad , in camera settings in the DJIgo app ?
Thanks Rob Denny in Fla.
You can also format it while installed on the AC using the app. I forget where the option is, I think in the camera settings.
On the status screen at the bottom where it shows the card capacity, there is a tab beside it to format card not sure if this is the proper place to do it tho, I have never formatted a new card
Nip
