Max mAh
Hey, Im curious. I got a F450 with Naza M v2. Im trying to add 2 and possible a 3rd battery. I have enough batteries in 11.1 and 14.8. What would be the Max mAh that the naza can take before I burn it out. Im also building a F450 with the A2 controller. I would like to add 2-3 batteries as well. Both of them have FPV setup.
mAh is capacity of the battery and will not burn something out. Sort of like size of a gas tank.
It's the voltage supply to the Naza that will do the damage and I believe it is rated at 4.8-5.5. vdc.
Another issue to consider is weight of added batteries as that will stress motors and thus ESCs.
hi, I did think about the weight. the reason I was going with 11.1 instead of the 14.8 is because of the weight. Ever since adding the FPV, my flight time dropped dramatically and I would like to regain it if possible. I have the 960kv and also 800 kv, I think ill get better times with the 800 kv from what I researched and read from forums online.
Utica
