Max flight altitude won't save
Massachusetts
I'm in the main controller settings and trying to set the max flight altitude. It doesn't matter what I put in, it's not saved when I got back to look at it. For example, it entered 500M then hit "done". The message about altering the max setting came up because it's over 400'. I pressed "Agree", Xed off that screen then went back to see it at 0. So I tried 100M. Xed out, went back in and it's still at 0. Am I missing something?
Thanks!
Thanks!
Are you doing this while the bird is on and connection established? If not, do so.
Just a reminder, many of the settings will not 'take' or be stored if the bird is not on and connected. That's gotten more than one pilot into trouble when a setting reverted back to some previous setting because the bird wasn't connected.
That's what it was! I changed the setting with the bird connected and it worked fine. I did a lot of research while I was waiting for this to come in but I didn't see that mentioned.
Reactions: Jeff Bohner
