Magnetic lock on yaw arm
Does anyone know how to remove the motor from the yaw arm and gimble arm? Is that magnetic lock pressed in there?
should be able to pull apart from the other side just with bare hands.
It separates and connects back together pretty solid but I was still able to separate by pulling apart the two
Should end up looking like this
Try holding like this and firmly grabbing the camera body with other hand
Or very carefully pry open with plastic pry tools or super very carefully with small flat head
Still no luck. I get what you're explaining but I get no budge. I'll keep truckin' with it.
If you were (or are) trying to get Part A out of Part B, I think it attaches to Part B with screws. I might be wrong though.
But if I'm right, you have to remove the rear cover to access them.
Sent from my SM-N910V using Tapatalk
It seems like it won't budge but it requires a bit more force than you would imagine. Just make sure you pull it straight off.
Sent via Galaxy Note 4 & Tapatalk
intertronixlabel
