- Joined
- Mar 24, 2017
- Messages
- 31
- Reaction score
- 18
- Age
- 46
Thanks for your hard work James - very informative. Can I ask a question. I have a P4 with a boosted MaxxRange antenna, as well as the Evo Lite. MaxxUAV recommends leaving the setup in auto. I'm wondering why that is and if that logic stands up to your findings? You mentioned in your video the sweet spot was quite narrow? Is it worth unlocking the extra channels if there is so little wiggle room for adjustments?
This is my setup as well. I think, as mentioned, MaxxUAV can't legally recommend using the hack. But that doesn't mean it's not going to work better. Based on the VSWR of that antenna, you'll get the most out of it when using ch. 20-24. But using other channels will still be better on that antenna than on the stock. Here's why:
The MaxxRange antenna has a forward gain of 10.5dB. The stock antennas are 3.5dB. The VSWR of the MaxxRange would need to reduce gain by 7dB before it has no benefit over stock. A VSWR of 6 equates to about 3dB reduction, while VSWR of 15 = 6dB of reduction. Look at the chart I plotted, which shows the entire 32 ch range is less than VSWR 15. So down at the lower channels you're getting gains of about 4dB over stock, while in the sweet spot of ch.20-24 you're getting the full 7dB over stock. Up at ch.32 you're getting near the stock levels of 3.5dB.
