Lost signal before max 500m
Today I managed to get to 150m distance and a height of 300m before losing signal.
Is this normal for a standard, or is there something i'm missing. If it makes any difference I had 10 satellite bars and I was on a mountain so interference shouldn't be an issue.
However once I cancelled RTH at around 150m distance and 150m height I kept getting RC signal weak but this would only appear for around 3 seconds before returning to full signaland this happened for the rest of the flight.
Any help would be much appreciated,
Hi
I had the antenna pointing directly at the drone if that helps. Is this the correct way to have it while flying. Thanks
No,someone will be along soon with a link how to do it.
Thanks for your reply
I just had a quick read through the manual and saw that dji recommend keeping the antenna perpendicular to the legs. I have tried this before but I still seem to get the rc signal weak anywhere past the 200m Mark.
Reactions: Brayan2134
@Ellis Hughes,
Welcome to the forum!
Let us know with your results.
Rod
jeetbuzz360
