Losing signal / record
Hi. I have a phantom standard 3 with a modified extender by ELITE DBS. It flew fine before, then suddenly one day it started losing signal and reception and returns to home almost immediately as I start to fly it. It's fine when it's near me or about 20 feet above the ground. The firmware is up to date and was fine before and after updates. I also can not start and stop the record button easily anymore. Sometimes it would start on its on. Other times it would not be possible to stop recording.
I've had a few hard landings and once the copter even flipped upside down. If any attennas are loose, where can I check? Thank you.
Did you install the antenna mod yourself? If so, I wonder if one of the connections in the controller has come loose or off?
Don carlos
