looking for phantom VC40 items specifications
antpoli said:
hi folks,
I'm looking for the specifications of the phantom VC40 items: motors, props, ESCs; on DJI web site I cannot found (neither on wiki).
I'm looking for something like http://www.hobbyking.com/hobbyking/stor ... W_CCW.html
anyone does have? or does know where to find?
thanks
Seems to be the best thing available:
Basic Parameters
Operating Temperature
-10°C ~ 50°C
Power Consumption
3.12W
Take-Off Weight
<1200g
Hovering Accuracy (GPS Mode)
Vertical: ± 0.8m
Horizontal: ± 2.5m
Max Yaw Angular Velocity
200°/s
Max Tilt Angle
35°
Max Ascent / Descent Speed
±6m/s
Max Flight Velocity
10m/s
Diagonal Distance (Motor Center To Motor Center)
350mm
Phantom Prop Guard
Weight(Single):18.7g
Size(Single): Angle(155.0°) Radius(112.32mm)
Whole Size with Four Prop Guards: 575.5mm
ESC Sound Introduction
Ready
♪1234567
Throttle Stick Is Not At Bottom
BBBBBB…
Input Signal Abnormal
B——–B——–B…
Input Voltage Abnormal
BB—BB—BB—BB…
Charger & Battery Parameters
Charger AC Input
100-240V
Charge Current
1A/2A/3A
Current Drain For Balancing
200mA
Power
20W
Battery Type
LiPo
Transmitter
Working Frequency
5.8GHz ISM
Communication Distance (Open Area)
CE: 300m; FCC: 500m
Receiver Sensitivity(1%PER)
-93dBm
Transmitter Power
CE: 25mw; FCC: 125mw
Working Current /Voltage
80 mA@6V
Battery
4 AA Batteries
FC40 Camera
Image Sensor
HD 720p/30fps
Lens
Aperture F2.2
FOV
100 Degree Wide Angle
Focal Range
25cm-infinity
Wireless
IEEE 802.11 b/g Compliance
Wireless Mode
Direct Mode
Mobile Wi-Fi Video Size
WQVGA
Battery
Built-in 700 mAh Li-on Battery
thanks but I'm looking for something more specific for each component (detailed specs for motor, detailed specs for ESCs, detailed specs for props, etc.)
