Loading litchi maps
Plymouth Ma
Hi, I'm using an iPad mini wifi and would like to load maps so when I'm away from wifi I can still set up missions... Any way to do this? Currently I use litchi and save a mission then I can pull it up when I get to the starting point. But if I go on a hike and don't know where I'll be then I can't do that. Any ideas?
Thanks
Thanks
When you have wifi, open the app and scan the map until you are over the area that you are interested in. Zoom I until you have the scale that you want and then close the app. The map will be cached and available when you turn everything on at the site. This presupposes that you have 'map cache' turned on in the app. DJI Go app does th same thing.
