Litchi App
As of now, is the Litchi app working very good with the P3S? Heard it got some bad glitches with P3S most recent firmware.
From Litchi's update log:
Version 3.10.7
- due to a bug in the DJI firmware, Follow, Focus, Track and VR with Immersive/Joystick Head Tracking modes are no longer usable with the following drone models and firmware versions: Mavic Pro (v01.03.0550 and v01.03.0500), Inspire 2 (v01.0.0240) and Phantom 4 Pro (v01.03.0418). If you are using one of these firmware versions and wish to continue using the affected flight modes, either downgrade to a previous firmware version using the DJI Assistant 2 PC/Mac app or wait for DJI to release a new firmware that will fix this bug
Litchi is working well with my P3S. All features work, but tracking is a bit hit and miss.
Works great with a P3S. I think Litchi adds more functionality to the P3S than most other Phantoms. It gets around some of the signal strength limitations of wi-fi comm...at least on waypoint missions. Well worth the cost.
Reactions: Pharm
Sorry, a little out of topic...
I've downloaded beta testing version of litchi app on my iPad. I haven't try it yet. What will happen after 70days testing period is over. Can I keep the app? Will it still be working? TIA
LITCHI is worth every penny, especially for the standard. I haven't touched the go app in forever!
I totally agree. Love Litchi. Don't get all the false and alarming alerts the Go app gives.
One thing I wish Litchi would do however is record video to my phone like the Go app does.
Finally got a chance to try Litchi earlier today. Just a simple P-Mode flight. I think I like it.. Especially voice warning on altitude and distance. I can keep eyeballing the aircraft up to 1km. Heading back manually before rth. Video feed was solid throughout the flight. Will try a simple waypoint mission tomorrow...
I use DU Recorder on Android to record on my tablet. That way I have the high res video on the SD card and a total screen version with all the telemetry data recorded by DU.
I really have no use for the very low res video that GO records and in fact I switched it off ...
I only use GO for settings and items that Litchi doesn't do such as calibrations etc. Once done - I then Force Stop GO and only use LItchi.
Nigel
Just make sure you map your route out relative to ground. I see a good amount of people moving to fast with litchi attempting a waypoint and flying into something. Just make sure you do your research!
Reactions: Darren_P
