Flight data is recorded in the application folder in my case in my phone in DJI/dji.pilot/FlightRecord" folderI wondered do I need a tablet with sd card capabilities to record flight details
I'm using a nexus android tablet But can't seem to find anything that relates
And be sure to connect in MTP mode with pcI'm using a nexus android tablet But can't seem to find anything that relates
The next update will include a Virtual Reality mode compatible with external goggles such as Gear VR, Homido, Freefly VR (120°fov), Durovis and generally most google cardboard like devices.Could you give us a preview whats coming up next in your app?
Since celullar network is not required, no there should be no problem at all.Is there any problem to use my samsung and litchi without any cellular network in ground station ? (I plan my trip with wifi first )
It will in FPV mode, and I believe it will in GS mode but with I am not 100% sure as DJI does not make this clear. Best not to rely on it and keep it safe.by selecting the RTH when low battery, does it mean that if I use ground station and if the trip is too long, the phantom will return home when detecting it won't have time to finish the trip because of no suffisant battery ?
That's weird, what did the waypoint speed slider show after loading the online-created mission? Was it at the max?
Thanks. That is probably the only thing I didn't try. I did send the report through the app once I was done. I'll retry the the auto take off. I have another Samsung Galaxy Tab 3 I can try as well. Figure the same tablet should give a fair and equal comparison.Hi,
Flight logs won't help determine the reason for crashes, for that we have crash reports, which are sent automatically in the background if you start the app at least once while being connected to internet after the crash.
Regarding the loss of control, this is normal behavior, after an automatic take off you need to use the controller S1 switch in order to regain control (flip from top to mid position and back to top position straight away). In the next update, we will have a message that pops up after initiating an automatic take off.
