Litchi 4.10.0 vs 4.17.0. Any differences?
Hi folks,
Any idea what the differences are between these two versions of litchi? Both seem to work with P3SE (so so) but anyone has any idea if there are changes in functionality?
Cheers!
By the way, whay is that some versions of Litchi work with P3SE and some other don't?
Any idea?
Maybe the WIFI channels?
All versions of Litchi should work with the Phantom 3 series, provided your smart device can run (handle) them.
Missions generated in the mission-Hub dot NOT work with version 4.10.0, you need version 4.15.0 or higher.
Issue:
Upload failed: The waypoint has an invalid shoot photo distance and photo time interval combination (code:-5128)
or
Upload failed: Waypoint shoot photo distance provided is invalid.
Perhaps the DJI SDK for the P3se doesn't support it.
Like the SDK for the Mavic Mini doesn't support waypoints.
or a mismatch between the SDK and the AC/RC firmware.
Litchi always uses the latest SDK for each supported drone, when DJI makes changes to a specific firmware they sometimes have to implement this in the SDK as well, like added features. Sometimes a bug elswere occurs in the SDK or firmware, which then gets resolved in another SDK or firmware update,
