Landing gear for P2
Is there any landing gear out there that will get out of the view of the gopro on a HD 3D?
I saw a post about lowering the gopro, but then it would hit the ground first.
Spread em wide, make em long, get them out of view:)
I use the taller version of the stock landing gear DJI released for the H3-3D and I film in Med instead of Wide and I rarely catch the landing gear in the shot.
I did not see anything that stated that there was any that were longer, bigger or taller. Can you share a link please.
Thanks.
Thanks.
The ones I'm referring to are just a bit taller (4-6mm I think) due to a slight extension near the top. Come to think of it they might come stock on the P2V+ as well, I think I remember them first being spotted on one of the first released V+ examples.
I got mine as a part of DJI's H3-3D retro-fit kit for the early P2's, they also come in the P1 version of the kit:
http://1uas.com/Camera-Mount-Gimbal/DJI ... or-Phantom (that's the one for P2's)
dirkclod said:
That's what I was looking for taller not the wider ones. I looked and was one backordered and one was not. Are they both the same as in fit on a P2V ? IYO
Should be, yes, since the P2V uses the same shell and leg mounts as all P2's. I've used both types (shorter and taller) interchangeably on P1 and non-Vision P2 bodies.
