- Joined
- Jan 19, 2014
- Messages
- 3
- Reaction score
- 0
Does anyone know a good ND Filter to use on the GoPro Hero 3 to reduce the jello effect which occurs on bright days?
Thanks in advance!!
Thanks in advance!!
ladykate said:Jello effect is usually caused by vibrations. Isolate the camera and balance the props (if needed).
Ozzyguy said:I suspect that it so a bit of both. When high frequency vibration come close to what the shutter speed is then you start to see jelly as we say in Australia. Imagine a vibration at 60 cycles per second bumping a camera that is taking a shot each time it is bumped(ie 60 frames per second)
ladykate said:Well... I guess the original question (where can I get an ND filter) is to shop Amazon. However, I don't get jello effect when pointing into the sun or on bright days with my setup. Not saying it doesn't happen - just isn't happening to me. Jello effect is usually caused by vibrations - I base that on the 4 zillion posts on here about it. I have no doubt there can be other reasons, too.
I do think the filter is a good idea - especially a UV filter. It protects the lens that is just hanging out there ready to get scratched by a tumble on the ground and it cuts haze and defines the sky better (edit: was just informed that the 'cutting haze' thing doesn't apply to digital stuff so it would be more of a lens protector).
I DID get slight jello on my P1 until I isolated the camera with a kit.
CunningStuntFlyer said:skeeter said:I have some SRP filters, but they are way toooo big for flyin...
Why too big for flying?
They've worked fine for me.
skeeter said:Any recommendations for the UV filter? I have some SRP filters, but they are way toooo big for flyin...
I found this at AMZN: http://www.amazon.com/gp/product/B00HXA ... UTF8&psc=1
ladykate said:skeeter said:Any recommendations for the UV filter? I have some SRP filters, but they are way toooo big for flyin...
That would work. Go to Amazon and search on GoPro lens filter. The problem with the 37mm conversion is that once you put a polarized filter on the adapter, you get slight vignetting in wide mode. Everything is a trade-off.
