It's possible upgrade firmware on phantom 3 pro without sdcard?
Dear Brother,
Please be inform how to upgrade my P3P without SDcard.
I don't have the gimbal board and I can't connect the aircraft direct to the Computer.
Thanks in advance for your help.
Best regards
Husein Kusuma
Maybe via the USB slot under the name ?
Nigel
There are two USB sockets on the P3 ... one on the Gimbal, other is under a small panel below the PHANTOM name plate on the actual aircraft itself. Just pick up the AC and look where it says :
PHANTOM
PROFESSIONAL
You will see a small panel with a USB sign engraved on it, immediately below the Name plate. With your fingernail - just flip it open and under is the mini USB socket.
This gives access to internal main board and logs etc. I have no idea if you can update via this but if you don't have gimbal to put SD card ?????
Nigel
I am in same boat. I dont have a gimbal or canera installed . I see the usb port but do not know if ir can be used to update firmware or how to do it. Waited 2 hours on phone with dji yesterday and gave up.
