Issues with Camera Filters
So i have a phantom professional and i ordered new filters that screw on and is there some trick in getting the factory lens cover off. I only assumed being it was the professional it just screws off? Some do Some don't im confunsed..
I had hard time 2 weeks to figure out it was really possible to remove it.
I have had 3 now, & a couple of small drops of brake fluid on the joint made the hardest one easy to move.
You can use fine oil made for that purpose.
You can use the little plastic prop wrench that came with your Phantom to remove the front UV filter.
tpren3
