Is there any way to install older firmware?
Is there any way to install an earlier version of the P4 Pro V2.0 firmware?
I am having issues with the aircraft holding heading, it drifts off to the left. The only version that shows up in Assistant 2 is the current version (V 01.00.15.00).
Thanks!
Yes- plenty of threads here and tutorials on YouTube- search away....
Many are flying the current firmware without issue so it might be downgrading isn’t your solution. I would start with an IMU and compass calibration.
I have done numerous IMU, compass, gimbal and remote calibrations, nothing has changed. Someone in another forum suggested VPS calibration. While the problem also occurs above VPS height, it's worth a try and something I am going to do. Thanks!
Have you considered ONE bad prop...slight edge damage can Not allow that one prop to perform like the three others....Try a brand new prop...Then go for the other things as With the Birds asked and replied with above.
Reactions: TheKestrel
jakob08z
