Is It Possible?
Mobile, AL
As many of you know, the P4P+ Plus Controller has an integrated display which is advertised as being much brighter than a typical device we use with the P3A/P bird. The revised controller also supports 5.8 which is not supported by the P3A/P. Therefore, I assume if they did indeed link and at a minimum, that function would not be available with the P3A/P platform.
Specs:
The Phantom 4 Pro controller integrates an upgraded Lightbridge HD video transmission system that adds 5.8 GHz transmission support. The ability to choose between 2.4Ghz and 5.8Ghz allows pilots to cut through interference and eliminates image lag caused when flying in an area with extensive 2.4Ghz frequency use. This ensures the optimum range of a maximum video transmission of 4.3mi (7km)*.
A 5.5in 1080p screen integrated with the Phantom 4 Pro+ offers 1000 cd/m2 of brightness, more than twice as bright as conventional smart devices. It makes bright, vivid colors easily visible in direct sunlight. With this screen, a mobile device is not required, simplifying pre-flight preparations. As the DJI GO app is built into the screen, hardware and software can be fully optimized, further reducing video lag. Integration of an HDMI port, Micro-SD card slot, microphone, embedded loudspeaker, and Wi-Fi connection allow images to be edited inside DJI GO to be shared almost instantly. Lastly, a five-hour battery life makes the Phantom 4 Pro + a complete aerial imaging solution.
Has anyone successfully linked the P4P+ Plus controller to the P3A/P bird? If not, is there someone with both models in hand that could try it for confirmation and report back?
Additional questions include:
Does the integrated 1080 screen display the P3A/P 720 live feed and fill the screen?
Does the microSD card slot on the P4P+ Plus' newer HDMI Module controller provide ability to store and transfer live feed captures and photos to PC?
