Is it Legal...
What height would you consider safe to fly over neighbours
  • 30m or above
    Votes: 3 25.0%
  • 50m or above
    Votes: 6 50.0%
  • 60m or above
    Votes: 1 8.3%
  • 70m or above
    Votes: 0 0.0%
  • 80m or above
    Votes: 0 0.0%
  • 90m or above
    Votes: 0 0.0%
  • 100m or above
    Votes: 1 8.3%
  • 110m or above
    Votes: 1 8.3%
  • Total voters
    12
Is it legal in the UK to fly over property that you do not own such as neighbours houses as long as you do not infringe on their privacy and are high enough... Just wondering as it is not made clear in the CAA's drone code?
Just to be clear, "High enough " equates to 50 metres generally and 150metres over a congested area.
Reactions: Brizo
I usually try to keep around 50m above peoples homes due to the noise the drone makes. Sometimes higher. I rarely fly below 200m and often above 450m as I am in Taiwan with no height restrictions in many places. People do not own the airspace above their properties even though they think they do.
The 150 metres is away from, not over, a congested area. You're not allowed to fly over built up areas at any height.
It's not 'bull'. The Air Navigation Order defines a congested area as being 'any area of a city, town or settlement which is substantially used for residential, industrial, commercial or recreational purposes'
Reactions: Brizo
My statement was to do with ' not allowed to fly over 'built up areas' at ANY height...... Read the complete ANO.
You're quite an aggressive typist aren't you Phil. If you're going to make dismissive comments you should make your point clearly [emoji6]
Reactions: Philltayl
That is the law, not a recommendation
If your aircraft has a camera, Article 95 is the one that applies.
Believe what you want...I'm finished :);)
