Actually, it can't be. Regardless if you reinstall the iOS via DFU mode or not. Anytime it boots up and connects to a network to try to authenticate it's serial number which is registered to that Apple ID, it'll require you to login to either continue or unregister it.
So you remove the module that stores the serial number information to by pass it checking your serial with the apple ID it was registered to. I mean if you're willing to screw up your motherboard then I guess that would work.
Apple ID and password to remove iCloud from iPad, but if forgot Apple ID and password, we should fix iCloud locked iPad without password with the help of the tool, but it's better to backup iPad to computer in the first, and then use the tool to remove iCloud lock on iPad.
