Is it possible that an iPad could interfere somehow with the quality of the uplink signal? Once again, today, I performed back to back tests using both iPad and S6 Galaxy mobiles. The same location and remote controller was used for all tests.
First test was a litchi mission to test range. When using the iPad I started losing RC signal at around 350-400m and permanently lost at 520m. The exact same test using the android S6 and never lost signal once during the 720M long mission.
The 2nd test was using DJI Go app. iPad lost connection at 300 and RTH kicked in. I did mange to eventually nurse the drone to a bit short of 500m with multiple disconnects in between. Using the S6 I flew the drone without one disconnect until I hit 956m.
The 3rd test involved a long (16 minutes) Litchi mission. iPad version lost connection at 700m. It didnt come back till the drone was less than 400m from home. The S6 version didnt lose connection until it hit 1412m. Connection was restored around 1330M.
This is not the first time I have been performing these tests. Today was simply to confirm (or duplicate) similar problems in the past. Regardless of where I fly, I can say without reservation that my range when using the iPad is nearly cut in half. How can this be?? I totally understand the neither mobiles actually send the signal to the drone. I am left to wonder though could the iPad itself in some what or another interfere with the RC signal?
Yes, my iPad has Cellular and yes iI have tried test with it on and off. No difference
