Highly doubtful from what I understand, possible , yes.
You can fly with it its next to impossible to see if your out in the sun you need to hide in the shade and a sunshade helps, DON'T use if for other things keep it App free xcept for the Go app
Google is your friend just look at the specs (ram, nits)I didn’t consider the brightness. With it being an old device I imagine the display isn’t all that good. I might return it and get the Air 2, if that’s any better...
The Mini 2-Mini 4 and Air 2 are all old, outdated devices with archaic processors. You are going to find that all of them are very quickly run into processing problems because they are just old. Especially with how process-intensive the DJI app is. If you want an iPad, buy either the 2017 or 2018 iPad. It's significantly faster, with the newest one approaching the speeds of the iPad Pro, while simultaneously costing what a Mini 4 would.
Unless you have a Mavic Pro and want a tablet that fits the arms, buying the Mini series makes no sense. And same for the Air, that thing is old and slow.
Cheers Nick. Think I’m going to get the 2017 9.7” model. Just don’t get why it’s so cheap compared to the others out there
Because it's the mid-range model below the iPad Pro, and because the newest 2018 model allows for Apple Pencil use. The 2017 model is still good, though, and has significantly more power than a Mini.
I need one with anti glare. The iPad 2017 doesn’t have it. Looks like it’s going to be the mini 4 but once again I’m seeing mixed reviews on this regarding green screen with the P4P
The anti-glare is a joke. It is pretty much as good as useless, and I notice more of a difference by putting on a screen protector. If you need anti-glare, put on a screen protector or get a shade. The Mini 4 does not do well in sunlight
