Interchanging Batteries in P3P and P3A
Discussion in 'Pro/Adv Discussion' started by kphantom, Jul 13, 2016.
  1. kphantom
    I just bought a P3A and also have a P3P. I have 3 batteries I've been using in my P3P. Can I use them and the new battery I received with the P3A interchangeably in either bird?
  2. Jdhill
    Gulf Coast
    While I don't know this for sure. I would guess the answer to be NO. The reason I would say that is because some of the FW updates include updates for batteries. So if your P3A battery has the FW for that bird, I would not think it would work with the P3P.
    I would guess you could take the P3A battery and put it in the P3P and update it to the correct FW, but then I would think it wouldn't work for the P3A.
  3. Meta4
    Meta4 Moderator
    Staff Member
    Yes, you can mix and match them without any problems.
    The battery is specific to the battery rather than the Phantom and there is no difference in the way the Advanced and Pro use their batteries.
    Ted4797 likes this.
  4. Ted4797
    Florida and New York
    Meta4 is correct. I do it all the time. I have 2 P3pros and an advanced. The batteries are interchangeable.
  5. kphantom
    Do you have both birds on the same level of firmware?
  6. Ted4797
    No, I don't. I repair cameras for the P3 Pro and Advanced. There are no issues swapping batteries between them. The firmware issue is when you swap cameras.
  7. telescott
    I have seven batteries, they work fine in either of my P3P's with different firmware and also work fine in my P3S.
    Ted4797 likes this.
  8. jtludwig
    Wow seven batteries. That is impressive.
  9. Jdhill
    Gulf Coast
    Well there you go, shows how much I know. Lol
  10. kphantom
    Thanks!
  11. Paul A Byers
    If you want to go out for a fun day flying Litchi missions it's what you gotta do!
Similar Threads - Interchanging Batteries P3P Forum Date
P4 / P4P Interchanging Batteries Phantom 4 Pro Help Dec 13, 2016
Phantom 3 Pro - Interchanging P3 batteries. Standard/4k Discussion Jul 19, 2016
P4P : interchanging between DJI Go 4 (Android) and DJI Assistant 2 for firmware upgrade checks Phantom 4 Pro Discussion Feb 22, 2017
Interchanging 2312 and 2312a motors on phantom 3? Pro/Adv Discussion Mar 7, 2016
Interchanging cameras Phantom 2 Vision Discussion Aug 16, 2015
