INTELLIGENT BATTERY MODEL NUMBERS DIFFERNT
the new updated battery that came with ph-2 v3 has a differnt model number than the one they gave for free, i cant let it discharge. HELP
there are 2 models numbers a v2 and original. they should work and act the same. not a problem.
You may need to expand on what kind of issue / trouble you are having.
The more info provided the easier it is to find help
DJ
ok, PH2-5200 mAh-11.1v and then a reg battery that i cant let discharge when it sits for 10 days or more. i cant find the newer battey
if they came with your phantom you are fine , different mfg dates and different part# is normal as products evolve
if you want it to go to 50% put in quad and let it sit a while turned on, or better yet fly about 8 minutes....
the batteries are correct and fine for you quad.
have you connected to assistant program on pc and check each battery to see if any updates for firmware etc
Update the firmware on the battery that won't discharge. It has old firmware on it, the newer updates add this functionality.
It's done via the Phantom assistant.
Xandian97
