IMU calibration?
Reading some posts here that mention IMU calibration is important after FW update. When I turned my P4P v2 on for the first time I had to update the FW then went into the menu and am not able to update the IMU as it shows good.
Should I be concerned? If so, how do I force it to calibrate?
Thanks all!
You should not need to calibrate the IMU after installing new firmware. If you'd like to do it anyhow, you should do it like this:
Thank you for that!
gspr
