IMU calibration
VA
Hello Folks,
I just bought a new P4P, and getting ready to get it set up. Are you all calibrating the IMU with DJI Go 4, or DJI Assistant? Also, which one registers you drone with DJI?
Thank you for your help.
Terry
You can register your Phantom and calibrate it using DJI GO 4.
When you set up the new P4P the activation process is automatic and registers with DJI......that gives you 48 hours to purchase the Refresh if you want. I upgraded from a P4 to the P4P and it was seamless in the activation process and I did break down and buy the Refresh since I have already crashed one P4 the odds are still in favor of Murphy's Law.
That's great to know. Thank you, Paul.
Is it obvious where to do that in Go 4? I have only used Go 3 so far.
It's the same process as DJI GO 3. The two apps are nearly identical.
Reactions: John Locke
Jerry P
