Professional Image/Camera Direction
Discussion in 'Phantom 3 Help' started by randika, Sep 3, 2015.
  1. randika
    Hi all,
    I'm in a process of geo-referrencing images captured from Phantom 3.
    For best results I planned to access the direction of the image when it is captured.
    But my program return following error.
    Undefined index: GPSImgDirection
    But I could access GPSLatitude and GPSLongitude with my images. So I
    need to know is Phantom 3 image metadata consists of GPSImgDirection.
    If there is how to access it.
  2. Meta4
    Meta4 Moderator
    Staff Member
    Looking at the Exif data for a Phantom photo, you can see that under GPS Data it shows Latitude and Longitude but Image Direction and all other fields are blank.
  3. III% Streve
    You could look at the flight log, at the moment each photo was taken, and get the direction from there.
  4. randika
    Thanks for quickly replying.
    @Meta4 - Yes. I accessed the EXIF metadata. That's the problem. Couldn't find the
    metadata field for GPSImgDirection.
    @Streve - I read the flight log from mobile phone pilot app converting to readable '.csv' format.
    But couldn't find any log file on Phantom 3 SD card. Still searching a way to easily read
    GPSImgDirection for a selected image.
    Cheers.:)
  5. Meta4
    Meta4 Moderator
    Staff Member
    The field is there - but it's blank because the P3 doesn't record thast data.
    [​IMG]
  6. koptik
    Had the same problem, now I just shoot the images North up ...
  7. III% Streve
    The log from the table has the direction the P3 is facing. But i don't know what its labeled.
    Sent from my SM-G920P using Tapatalk
  8. randika
    I could find a column labeled "OSD.headingCompass" on flight log from mobile. Comparing the image taken time with "CUSTOM.updateTime" column I could get rough idea about the camera bearing. With that my problem is partially solved.
    Thanks all for replying.:)
    III% Streve likes this.
Similar Threads - Image Camera Direction Forum Date
Delayed camera image Phantom 4 Help Jan 6, 2018
Since software update, lost app camera image and have flashing red/green LED on R/C. Phantom 4 Help Dec 8, 2017
No camera image Standard Nov 16, 2017
P4P Plus Remote: "No Signal" & No Camera Image - Help! Phantom 4 Pro Help Oct 20, 2017
Dark Blob on Camera Image Phantom 4 Help Oct 2, 2017
