I recently had the same thing happen to mine. I only got to fly it once! The antenna on the standard seems to be very fragile. No one has the exact replacement antenna unless you can buy it used from someone on here. I could not find a direct replacement anywhere. So your choices are basically get a similar antenna off amazon or ebay that requires you to modify your antenna mount, or take this an an opportunity to upgrade to the ITELITE or other long range antennas. I chose the latter option and it's worked great. A new controller is around $130 bucks, so I just put that money toward a DBS ITELITE and i've been happy with my choice. Sorry about your antenna. Best of luck!If you can buy the antenna, which I have not found one yet. The fitting is a very tiny connector at the end of the wire and connects to the board. The connector has a small dab of glue(?) I think on top of it to hold it in place from accidentally being knock off. You will have to remove that and replace the antenna wire that I would assume would come with a new antenna. I broke mine a couple of weeks ago. I played hell getting it back together. I would also like to purchase a spare antenna for mine.
As for upgrading the antenna?, don't know about that. I have never done it so I can't help you there. I don't see it as being a hard thing to accomplish.
If you do locate someone that is selling replacement antennas, I would like to know as well.
Hi,I recently had the same thing happen to mine. I only got to fly it once! The antenna on the standard seems to be very fragile. No one has the exact replacement antenna unless you can buy it used from someone on here. I could not find a direct replacement anywhere. So your choices are basically get a similar antenna off amazon or ebay that requires you to modify your antenna mount, or take this an an opportunity to upgrade to the ITELITE or other long range antennas. I chose the latter option and it's worked great. A new controller is around $130 bucks, so I just put that money toward a DBS ITELITE and i've been happy with my choice. Sorry about your antenna. Best of luck!
Hi,
Firstly thank you for your answer... But I have a question does the ITELITE is great ?? Is it working with the Dji bag ?
Can I have a link about the ITELITE ?
Thank you
I think the ITELITE is great, and from what I read on these forums, so does almost everyone. It will definitely extend your range. As far as the backpack, I don't know. I don't have one and I'm currently looking for a backpack/case that will work well for my purposes. I would assume you could take the antenna off and it would fit in your backpack, but I'd like to find one that accomodates the controller with the ITELITE attached.Hi,
Thank you
