How Do I Remove My Info From P4 I Am Selling?
2 questions -
1) Does the Mavic come with Follow Me Mode?
2) Is it true every flight log is saved on the drone itself? How would I clear my Phantom 4 so no one has my information?
2 questions -
I not sure how to clear the log but I believe the flight log is stored on an internal 2nd Micro SD slot. You can access it with DJI Assistant 2 using a computer. I do not know if you can wipe it or not. I've seen other users on this forum take pictures of the 2nd Micro SD slot and another user accessed it using FTP.
I do not believe taking the external SD card will remove the data.
Isn't it saved IN the drone takes though?
Basically I'm selling my Phantom 4 and want to make sure I delete everything possible.
The internal memory cannot be wiped, these logs are encrypted (even though it appears data can be pulled) and are for DJI to access when something goes wrong and they want to investigate.
Reset to factory settings and wipe your SD card and that's about it.
