Home Lock purpose
Lancaster, Pa.
Have tested the Home Lock feature a few times now to see how it behaves just in case I need to use it to retrieve the drone back home it the event I lose contact with it remotely and visually, and don't want to use the RTH instead. It seems to behave good for that purpose, but I'm not sure if it has any other uses. Doesn't seem you can fly the drone in any controlled fashion in this mode, as right, left, forward and back only make sense if your standing right at the home point and make sure your facing right at the drone. Which might be hard to tell if its a good distance away using just your eyes, VLOS. When not using your devices screen, FPV in other words.
home lock is awesome plus if you lose sight pull back there it is much easy way to fly
Reactions: gvsukids
Plus you can move left or right with the stick and your aircraft will actually circle the home point which is undeniably super cool and will definitely impress the chicks
Reactions: flpholt
Amazing how different folks see different things.
That's a life-lesson right there.
canadiansauna
