help with red flashing only
Thank you new to this, I have an fc40 and when I plug in the battery goes trough a cycle of flashes then only the red light flashing and will stay like that it wont respond to the controller and the remote is conectted because no flashing light inside the phantom only the indicator light flashes red. any help will be apreciated
I would plug it in the computer and run the assistant to check if everything is correct. Check your RC calibration as well.
I think you may need to calibrate the GPS just google it, it's easy to do. could also be that your controller needs calibrating but for that you will need to plug your phantom into the computer it's also easy to do. If you can't find what I've mentioned let me know and I will guide you.
I see where Thomas has his FC40 for sale.
