D
Deleted member 29014
Guest
Every time I map a mission and save it, it saves over (rewrites the previous mission(. Can't figure it out(?)
Couldn't figure how to do that.Do you assign a specific name to your mission?
When I click on the disk icon, it saves w/o asking for a file name.When you hit save, make sure you change from project 1 to your new name.View attachment 110191View attachment 110189
I'm using IOS, thanks for the answer. I exhausted my search for multi battery instructions w/o luck. Thank you.It does. If in iOS, the drone will continue where it left of. Ic you are on Android, it will start at the beginning of the line it was running at the time of the swap. According to Pix4D, you will have to pause when low battery.
Multi-battery / How to operate multi-battery flights
You can fly a multi-battery mission with Pix4Dcapture. Pix4Dcapture for iOS and Pix4Dcapture for Android provide different workflows to perform a multi-battery mission. If you cannot safely capture...support.pix4d.com
When you hit save, you get taken to the page where you can change the name and add more missions to that project.When I click on the disk icon, it saves w/o asking for a file name.
IT doesn't, it just saves, no page to change name appears...When you hit save, you get taken to the page where you can change the name and add more missions to that project.
Maybe this helps.IT doesn't, it just saves, no page to change name appears...
Hmm. I have an iPad at work. I'll try tomorrow and get back to you.IT doesn't, it just saves, no page to change name appears...
Thank you.Hmm. I have an iPad at work. I'll try tomorrow and get back to you.
Well that is weird. When I use Pix4D it flies non stop while taking the photos. It only slows down when it has to turn. Also, I was able to create various missions without closing the app on iOS. I don't know if it's your device being evil or mine being weird and working beyond expectations. I also found that the renderings done by Pix4D looked better than DD. I have never played with Map Pilot. I do all the processing with Agisoft Metashape.I was able to save several missions by shutting down the app in between saves. It's all academic now; the job (today) was a complete disaster.
The drone started the 300 ft. orthomosaic mission but would stop and hover every few minutes, Screen read “Going to land.” I RESUME the mission and it would fly ok for a while and stop again. Burned 3 batteries on 100 acres with all the hovering. In my opinion Pix4D Capture is nowhere near the reliability of DD or Map Pilot. The customer insisted on Pix4d; I have declined the job.
I do appreciate your help, Ansia.
