Help...cracks spotted
Let's see how it works and fly..tomorrow morning...[emoji106]
Kinda thought so. So no worries with plast aid or the installation of it? Or taking the shell off?
Hi Phil not sur I replied to yours..removing the shell not an issue...plast aid the same...honestly I wanted to keep it fluid and didn't add to much powder..need to.use the stick to avoid filling all parts...as.you know I've done it twice as the firts time I realized some spots were not covered and this is probably why I found a second crack under one of the screws..the second time was somehow easyer of course as I knew all the sequence..
Sandman. So you had no problem removing the tape from around the inside edges? It did stick to the plast-aid?
Ok guys I'm stuck. Did you have trouble removing the screw next to the landing gear Sandman259 & Ciccio? I am. Do you need to remove them. Sorry. Just stuck here
Phil this screw is a bit deeper that the others and for this you need a longer driver...I've mine which can be extended...a part from this the screw is just like the others...
