Has anyone ever soldered new hall sensors onto the gimbal windings?
Discussion in 'Phantom 2 Vision + Help' started by Monkeyleg, Jul 26, 2015.
  1. Monkeyleg
    I'm guessing that a good portion of gimbal problems are due to one or more bad hall sensors on the gimbal motor windings. In looking at them, they're in a tight spot to try to replace. I'm wondering if anyone here has done it.
    Thanks for any replies.
  2. hunch
    i did but won't do it again.. have about 30 of those stators in a box. takes too much time and pcb is easily melted if you're not careful
  3. Monkeyleg
    It's beyond my skill level. There's a guy in San Diego who does micro soldering. I might ask him what he'd charge.
  4. hunch
    why??
    just get a new stator. they are not available in many places but i have a ton if you need any.
  5. Monkeyleg
    The entire stator: windings, shaft(s), bearings, copper ribbon cable, sensors?
  6. hunch
    yes,
    just send me the picture of what you need. i have probably 20-30 of each
  7. Monkeyleg
    Well, here's a photo that you did of a yaw arm with the stator assembly: stator, sensors, shaft, bearings all in one piece. That's what I'd be looking for, but not just the roll motor. I'd be looking for the pitch motor and yaw motor stator assemblies, too.
    http://www.phantompilots.com/attachments/image-jpg.24506/
  8. hunch
    which parts do you need?
  9. Monkeyleg
    #1, if that's a pitch motor, which fits into the pitch motor housing, #2. Given the shaft length, #1 could be a base motor, which I don't need.
  10. hunch
    actually #1 is a yaw motor, the one that goes through the main board and housing and into the yaw arm
  11. Monkeyleg
    That's what I meant by "base motor". My brain's not working well tonight.
    I thought that shaft looked too long for a pitch motor. But I need a pitch motor in the same configuration you're showing that #1 yaw motor: with magnet, sensors, ribbon cable, stator, shaft, all ready to screw into the #2 pitch motor housing with three small screws.
  12. Desert Dave P
    do you fix gimbals too? i am looking for a place to send mine for repair..
    thanks Dave
  13. Monkeyleg
    I tinker with them, but Hutch and Burlbark repair them. ATK Drones, too.
    I made a device for testing the Hall sensors and the field windings. Out of all of the broken gimbal motors I have, only one has bad windings but just about all of the others have at least one bad hall sensor.
  14. hunch
    Dave, i do.
    let me know if you need help.
  15. Andrejka
    Hello all,
    After short googling I found that these sensors is Melexis US1881. I replaced one device on pitch axis, and after that gimbal works well.
    BR
    Andrej
  16. eric148
    Hello, maybe you know if these sensors are suitable for the yaw motor gimbal of Phantom 4. And if so where to buy them. Thank you
Similar Threads - Has anyone ever Forum Date
For anyone who has ever lost their drone in water.... News Jun 10, 2016
Has anyone ever cut the 100watt charger Standard/4k Discussion Jun 2, 2016
Has anyone ever thought about starting a IPTT Channel? Pro/Adv Discussion Feb 9, 2016
Has anyone ever sent your bird out as far as it can go letting the RTH feature kick in? General Discussion Apr 9, 2015
has anyone ever seen this? Phantom 2 Vision + Discussion Jan 14, 2015
