Loctite is not a glue. Plus, the two screw holes mentioned have metal inserts in the plastic. No loctite, which is a binder, not a glue, ever touches the plastic. Believe me, I've spent a bundle on this arm cracking business. Also, why is it that DJI uses a blue loctite material on the screws to begin with?Be advised: It's been posted that loctite will damage the area around the screw holes and can cause cracks. The glue and its fumes during curing can damage the plastic even if the glue never touches the plastic.
If you want to call it a binder, that's wonderful, but that has nothing to do with my point. I'm merely relating what I've read from posts by several very experienced and reputable members of this site.Loctite is not a glue. Plus, the two screw holes mentioned have metal inserts in the plastic. No loctite, which is a binder, not a glue, ever touches the plastic. Believe me, I've spent a bundle on this arm cracking business. Also, why is it that DJI uses a blue loctite material on the screws to begin with?
