h3-3d with phantom 1?
Hi
I have a Phantom 1 which was upgraded with the H3-2D gimbal connection kit. The H3-2D gimbal worked flawlessly.
Is this setup compatible with the H3-3D gimbal?
Thank you
Daniel
Hi. If you use PMU-V2 + GCU you will not have the chance to change the tilt speed of gimbal but it works...
The gimbal is tilting 1:1 with you finger move and it is totally unusefull...
If you use the upgrade board - i do not have informations about the tilt speed settings.
If somebody has - please share it!
ditri Posts: 2Joined: Fri Oct 31, 2014 7:56 am
Jerry P
